N_Cook
Mains fuse blew in the middle of normal use.
No mention of PbF anywhere but it is. Unlikely the problem though. Seems bad
thermal design as audio-out vaned heatsink has cooling air through it but
the non-vaned SMPS one does not have, as that intended? air will go through
the path of least resistance over the uncluttered preamp . I can see a
baffle going in here to direct air over this plain block heatsink. Anyone
experience of these little amps?
Both SMPS powerFETs s/c all round. Each has a discoloured patch on the
mounting-plate where the die overlies. No burning/blow-holes of these
powerFET encapsulations or 10R SMD gate droppers or anything else found
suspect from cold testing/close inspection, nor suspect looking PbF. The
SMPS supervisor IC ident is ground off and a schematic for a similar amp
has no ident. I could find details of any 8 pin 0.1 inch pitch package with
push/pull drive in 1991 DATA linear colated listing- any suggestions for
this sort of search?
p1 supply low side
p3 probably Enable
p4 Vcc
p5 and p7 hi/lo outputs
p6 mid connection to both output powerFET
Does not seem to be any thermal shutdown for the SMPS section
p1 supply low side
p3 probably Enable
p4 Vcc
