I've got the following relay design where I've got two relays sharing the same common directly from +12v of a car battery. The relay coil is powered by two different circuits. In most cases only Power Source 1 or Power Source 2 will be on. However, there will be occasions where power source 2 may be on for about a minuate max when power source 1 is also on. Questsion is, will that be ok? I can't see why not because technically if both are on at the same time, then all that's happening is the same +12v power is getting merged. As a precaution I could put a diode but i'm thinking is it necessary?
Any advice will be appreciated.
