Mark said:
I have a cabin in my backyard that has been wired to the 110V grid. I
want to remove the feed cable and install solar panels.
Rather than re-wire for 12V, is there amy technical problem with using
the existing in-wall 110V wiring?
Of course, for safety, sockets and lighti fistures will need to be
replaced with 12V versions, or at least relabelled.
Mark Fisher
There aren't many reasons to be off grid.
1) there is no grid available.
2) you derive some personal non-economic benefit, well being,
"hey look what I can do", from being off grid.
You can live in a tent...but unless you are willing to dramatically
decrease your needs for energy, there is no economically feasible
solar system, today. No, the schemes whereby you transfer the cost
to ME thru government subsidy or force the utility to buy electricity
at inflated rates raising MY bill don't count. I don't want to pay for
your system!
The current you can get thru the wiring is the rating on the breaker.
So you get 1/10th the power. Unless your peak load on the circuit
was less than 1/10th the rating, you're gonna have a problem.
See "living in a tent" above.
You don't want to put 12VDC on 110VAC wiring. Plug in a device
with a transformer and sparks will fly. Polarity is important.
Lotsa devices have non-polarized plugs. Call up the local electrical
inspector. If he's on his toes, he won't let you do it.
I can hear the villagers lighting torches to come after me.
"No that can never happen", "I won't tell the inspector", "he
has no jurisdiction", "I'll never have any visitors who might
compromise the system"...Use common sense. Stuff happens.
Put separate 12V wiring in the place, or use an inverter and
the existing AC wiring.
Go visit newsgroups that address these issues for details, but...
Use more than 12V for your DC storage system into the inverter.
Here's how you talk yourself out of the project.
These are round numbers, but the message is the same.
Turn on everything you want to power simultaneously and spend
some quality time with the utility meter. You need at least that
much peak power plus any additional for motor starting peaks etc.
Measure consumption over an average day in the season when you
use the most energy. Multiply that by
how many consecutive cloudy days you want to survive. Times some
efficiency factor. That's how big your batteries need
to be.
Google for insolation charts for where you live. That'll tell you
how much solar energy you can expect to get from a typical winter day.
Divide that by 10 for the efficiencies of the solar system and charging
system and and and...
Divide that number into the average daily energy requirement to see
how many square meters of panel you need.
A popular number is 1KW/square meter. Depending on the efficiency of the
panels and other system components you can afford, you're looking
at 10% of that on a sunny summer day with no buildings or trees
to block any of it. But averaged over the day, it's
a lot less. And in winter it can be near zero depending on where you live.
Add up the installed cost of all that stuff.
Bottom line is that solar power is a fool's errand.
There's no way it can pencil out on an individual basis with current
technology. Unless you can get someone else to pay for it...that would be
me...and I object to my tax dollars fueling your errand.
Wiring is the least of your worries.
Find a different hobby...like convincing the tree-huggers that we
need to get some nukes on line BEFORE we kill off all the trees.
