I have a 12v EL glow wire. It seems to come with some sort plastic cover at the end. I need to push the cover in to a hole but when doing so it gets tight. Can I remove the cover cap and refit it after I've fished it through a hole? What is the purpose of the end cap? As it comes of easily can I tape it or super glue it?
Also can EL wire be cut? And then cover fitted again? Or does the driver drive the length of the wire and cutting it effects the electronics ?
