12V 4amp DC out 120Vac in power supply schematic needed
G
George
I am looking to build a power supply for a LCD flat panel monitor.
3
3T39
Hello, George!
You wrote on Tue, 07 Mar 2006 08:44:39 GMT:
G> I am looking to build a power supply for a LCD flat panel monitor.
G> Thanks
An old PC PSU can be utilised for this, with the benefit of good regulation.
If you use a modern ATX unit short out pin 14 to ground to get it to start
up. Yellow is +12V
With best regards, 3T39. E-mail: [email protected]
Arfa Daily
Such power supplies are available dirt cheap, ready built. I wouldn't even
consider building one. Had to renew the one on an HP LCD monitor here,
recently. Just got a generic 12v 4amp switch mode psu from one of my normal
component suppliers.
Arfa
Sam Goldwasser
3T39 said:
Hello, George!
G> Thanks
up. Yellow is +12V
You may need to provide a load on the +5 or other output for it to run
stable. This was always required of older AT supplies, don't know how
many ATX supplies require it.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
