Ï/Ç David D Ýãñáøå:
I 'm from greece and i don't know so much english. Yes you can use
this battery the problem is in Volts. If you have a batterry with up
of 12V don't try to use it with this monitor because you burn this
monitor. The 4.5 Amperes of battery say how much current you can use
from battery and if you have a monitor with up of 4.5A and conected
with this battery you burn the battery and maybe this can make the
battery to BOOOOOOOOM. You Understand?
'thanks for the replies.
Right now, I am interested in getting 12V battery with a 4.5
amperage. The only problem is I am doing it DIY and trying to make it
on the cheap - therefore I am stuck with finding a way to RECHARGE the
battery. Of course without LED lights and levels, I won't know know
if it is charged or not. And yes, I don't want to blow a $100.00
monitor either. My main purpose for this is to create a portable
monitor system. I went to Canadian Tire to find the 12V cordless
drill batteries, but they only pump out 1.5 Amp, so it is getting
harder then I thought...
Well, now we're getting to the root of the problem. The answers that other
posters have given are correct, for the most part. The issue now is.. how long
do you need to operate the monitor on battery? The ampere-hour (AH) rating of a
battery is useful in determining how long the battery can supply power. The
load current is a major factor in determining this time. The chemistry of the
battery is also a major factor in this calculation.
A fairly good tutorial on batteries, AH ratings, Loads and recharging is at
http://homepages.which.net/~paul.hills/Batteries/BatteriesBody.html. I suggest
that you read that with great attention and you will get a better understanding
of your situation.
For your portable application, I suggest that you look primarily at sealed
lead-acid (SLA) batteries to start. Newer chemistries such as Lithium-Ion and
others typically used in laptop computers have a higher energy/weight ratio, but
are significantly more expensive.
Dave M
MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
address)
Life is like a roll of toilet paper; the closer to the end, the faster it goes.
