HI,
I had ordered a LED strip : http://www.ebay.in/itm/5M-LED-Strip...31645865522?ssPageName=ADME:X:PPPSBRE:IN:1123
I cut it into two parts around 3.5m and 1.5 m in length. 3.5 m strip I connected with 12V adapter which came along and its working fine.
When I connected 1.5 m strip with the another similiar adapter, after 5 mins it burnt out and fumes were all over. Luckily I was around and saw it happening otherwise it could have been a mishap.
So the question is, Why it could have happened. IS it due to the fact that I reduced the effective resistance(by shortening the strip) while keeping the same rated power source. With lower resistance it could have drawn higher current and it might have caused the burn out ?
If I am correct then should I have a power resistor in series to avoid this ?
Any suggestions or analysis are welcome.
Cheers
Dashy
Cheers
Dashy
