128 and more input using a PIC16f628
Ben Bradley
Some people are telling me its not possible to multiplex serial out
parallel in shift registers.. As I've never used these.. is this true?
Or is it possible?
I forget the part numbers (you need the ones with the appropriate
features: load, clock, serial in, serial out), but I presume you mean
can you cascade (or 'daisy chain') such shift registers, and yes you
can do this for however many inputs you have. It's a simple way to do
it. The processor triggers the load signal (one time for each read),
then toggles a clock line and reads the input port for each bit of
input.
