This is a tough problem to solve with a linear voltage regulator because of the large (10 A) current required combined with the need to drop about 14 - 6 = 8 V across an external pass transistor to boost the current capability of the LM7905. The transistor will dissipate about 80 W under these conditions, and its maximum power dissipation with a perfect heat sink is only 100 W. There are plenty of one-transistor "bypass boost" circuit examples, but they all share the common problem of what do you do with all that heat?
It gets pretty hot under the hood of your 1936 Chrysler Airstream... you wouldn't want the ignition to fail while out for a cruise! Why not upgrade the ignition system to a nice 12 V capacitive discharge system? You could probably run the fuel gauge with a suitable current limiting resistor from -12 V too. But while we're at it... since you ditched the original 6 V system (which presumably had a generator, not an alternator) why not ditch the positive ground too? About the only thing you would then need to replace from the factory-original configuration would be the radio, unless you want to provide a +12 V DC to -6 V DC converter to power just the radio...
If you want to continue down the path you are on, I would seriously consider using a buck switching power supply to drop from a nominal -12 V (maximum -14 V) positive-ground power supply input to a -6 V positive-ground power supply output.
I would imagine
@KrisBlueNZ has more experience with this than I currently do. Finding an off-the-shelf isolated DC-to-DC buck converter would probably also do the trick. Something with 12 to 15 V DC input and 6 V DC output at 10 to 15 A sounds about right, but nothing comes to mind yet. Try Google with those search parameters.
If you can find an isolated positive input/output converter, you can power it up by connecting its positive "input" to your automobile ground and its common to your -12 VDC battery supply. The -6V DC output would then be taken from the converter "common" terminal with its "output" terminal connected to the automobile ground. Again, this only works if the converter common can be operated in isolation from the automobile ground, and the converter input is isolated from the converter output. Might have to wrap the whole thing in plastic tape to prevent "accidents" from happening... and it will confuse the hell out of anyone trying to troubleshoot it later unless you document what you have done and why.
Edit: Re-reading what I wrote, I hereby withdraw any recommendation for plastic-wrapped DC-to-DC converters, isolated or not. Too many things to go wrong. You need a buck converter that accepts -12 V DC input and provides -6 V DC output. Period. Good luck with that... maybe Kris can design one for you. I should probably go back to messin' 'round with amateur radio and vacuum toobs.
