G
greenwanderer108
I rigged them on my bike to test the actual output but can't get any rea
readings (400 milivolts max), let a lone enough power for even th
smallest loads (i.e. 3volt toy motor). Either I got ripped off or I jus
am not hooking them up right. I think its the latter.
At the bike shop, they had two different kinds available. I believ
they're both made in Taiwan. One of them had only one terminal and tha
was rated 6 volts. The type that I bought (quantity = two) aparently ar
rated between 12 - 16 volts and have two terminals. One reads T and th
other H. The salesguy explained it stands for Taillight and headlight. S
they're made for lights.
Anyways, since they are rated atleast 12 volts, I figured it would b
sufficient to use for other applications such as a charger for the powe
pack in my electric bicylcle set up.
I initially understood that generators are just like motors with th
electromagnetism (two polarities) so how is it that the 6 volt generato
can have only one terminal.
And what about these two terminals for head and tail light. Obviously the
aren't the equivlent of positive and negative leads, cause I can't get an
power or readings from my digital multimeter (or anologue voltmeter) wit
the the leads hooked up to positive and negative . I remember the guy a
the bike shop saying something about the both H and T leads bein
positive, and and that the negative lead of the light (or other load) mus
be grounded onto the generator. I tried, but still couldn't get any acurat
power--or readings with the thing spinning as fast as I could get it.
How do negative and positive polarities play in with such generators? Wha
am I missing? If it's rated at 12 volts, why can't I get any more than 40
milivolts. Do I have to ground the load some how or ??? I am lost.
If it was like a motor with negative and positive leads, it would be s
much easier . Can someone please help me out here? What if I want t
combine the power of both of the generators in series or paralell?
Thanks in advance
This message was sent using the sci.electronics.basics web interface o
www.Electronics-Related.com
Thanks in advance
