Hi. I have Siemens 5TC8424 potentiometer/switch (http://www.elektroland24.de/out/media/5TC8424_Bedienungsanl.-5TC8424.pdf), 0-10V transformer/driver (https://drive.google.com/file/d/0B9l3lhqYEi8vREctSmtiajZHU1E/view?usp=sharing) and 36V 36W 900mAh LED panel. The problem is that I cant control the driver (and LED is not lightning) with that potentiometer.
I connect all parts as shown in Siemens connection example. So the potentiometer has input of L and outputs it to the driver and also outputs 1-10v signal to the driver. Driver additionally has input of N. I have measured that the driver correctly gets 220V. However, 0-10v (control) doesn't provide any voltage. Is that normal? Driver outputs 3-4V only while it should output 36V .
I have told it to the supplier of the driver and led and they responded to me that the potentiometer should output 10V on 0-10v wires (http://1drv.ms/1DTQPI6). But they have connected both L and N to their potentiometer's input. Siemens potentiometer cant accept N as I know.
So, are here several different 0-10v technologies like active and passive? Or is my Siemens potentiometer broken and actually should output 0-10v?
