So, should I try to get some of the LMR-400 you speak of?
Would that fit into the same SMA connectors as I bought for the RG58?
What makes LMR-400 a good choice?
Was wondering.. the yagi has a short length of the RG58 coax which is soldered to the driven element inside the connector box, with the other end (4 or 5 inches away) terminated with a female SMA connector.
If I used a different cable for the main run, e.g. this LMR-400, would that cause some kind of impedance related problem where it meets the RG58
I was thinking of taking the LMR-400 straight to the connector box and soldering it direct to the ends of the driven element to avoid that. Would that be a good idea, and should I include some kind of balun arrangement if I do that?
Sorry for sooo many questions
edit.. ahhhhhh I found a label on my cable: "LMR-195 50 ohm coaxial cable" "KINGSIGNAL"
http://www.timesmicrowave.com/downloads/products/LMR-195.pdf
hmm.. LMR-400 specs
http://www.timesmicrowave.com/downloads/products/LMR-400.pdf
the attenuation figures seem a heck of a lot better for the LMR-400
