This is amazing stuff!
Hi Aakash
Please make up your circuit on some protoboard, with the jumper wires clearly visible. The important issue here is not the protoboard, it is that the wires should be easily visible and the circuit tidy enough to be traced visually in a photograph.
Please use led's in your circuit instead of silicon diodes. Please mark the anode side of the led with a thick black marker so that polarity can be clearly seen in a photograph of the circuit. Use the appropriate resistance (we'll help you work it out if you like) to make the led's glow brightly enough to be seen in a photograph.
Please post photographs of the circuit working as you describe, and post the circuit diagram you have followed.
Hi Aakash
