Jamie
You are absolutely lost...John said:Jim Thompson wrote:
On Sat, 29 Sep 2012 13:27:12 -0700, Jim Thompson
On Sat, 29 Sep 2012 14:16:54 -0500, John Fields
[snip]
Since Toyota's have been described as "5-wire", I presume that's...
Brake Left Brake Right
Turn Left Turn Right
Ground
So each side is independent and "Turn" (flashing) trumps "Brake"
(steady).
...Jim Thompson
Mine works like that and provides hazard mode flash as well, with
three relays instead of four:
. +12
.BRAKE---+ |
. | O K1
. [COIL]. . ./
. | O->/ <-O
. GND | NC |
. | +----|--[LLAMP]--+
.LFLASH>-+ | | | |
. | | O K2 | GND
. [COIL].|. . .\ |
. | O-> \<-O
. GND | NO |
. | +----|--[RLAMP]--+
.RFLASH>-+ | | | |
. | | O K3 | GND
. [COIL].|. . .\ |
. | O-> \<-O
. GND NO
Are both "Brake" lamp circuits wired together? I have a wiring
diagram for my Q45... I guess I should open the manual and see how
Infiniti does it.
...Jim Thompson
Booboos. We fret over brake and turn, but what about tail/running
lights?
...Jim Thompson
There's no requirement for them to be included.
Around her, in Arizona-land, you're required to have at least one
"running" light or a "flag" ;-)
I'm wondering if "5-wire" isn't actually...
Running
Brake
Left Turn
Right Turn
Ground
...Jim Thompson
I found this...
http://tinyurl.com/44m6pmu
...Jim Thompson
Right, something I stated way back at the start of this tread and I
took that from memory.
So, it is true then, if it's on the internet it must be true
otherwise beware of information coming elsewhere.
Jamie
Do neither of you have a clue?
The OP asked for steady brake lights when the brake pedal was pressed,
unless a directional signal was invoked, at which time the directional
signal would override the brake signal and flash the directional lamp
on that channel.
YOu really know how to screw up things.
Jamie
