David L. Jones
Microsoft are recalling 14.1 million X-Box power cords!
http://www.xboxworld.com.au/news/leading.php?idNews=893
Dave
Dave
David L. Jones said:Microsoft are recalling 14.1 million X-Box power cords!
Dave
So they are making the cord inflammable or have a higher melting point,
to repair what is actually a power supply problem ????
If the OLD power cord's xbox end plug is getting to melting point, then
the new one will still cause injury as its at a high temperature ?????
plug at high temperature, and I remove it from the xbox and touch it to my
nose. Now I have a burnt nose ???
I dont get it.
How can a power cord be faulty ?
What if I have a $150 custom power cord ? what spec does it have to be to
be safe ?
Surely they have to recall the actuall X box and replace them with ones
that dont get a hot power supply ????
** That is for sure.
** Lots of ways.
** Lots of specs need to be met.
X -box.
Have you never seen a corroded AC mains plug get very hot in use due to
high contact resistance ??
Ever heard of I squared R ????
Well I am glad you agree, but you clearly dont either, you useless excuse
for used toilet paper.
Usually the only thing that varies from device to device is the amperage.
What specs would you say the Xbox needed that was wrong with the power
cables that were supplied ???
You dont answer, because you dont know.
But wont it do that to any power cord then ?
Yes, I have seen that. On a clothes drier.
xbox , clothes drier. I dont get it.
you havent explained anything.
As if linear R is be found in this context.
Fred said:So they are making the cord inflammable or have a higher melting point,
If the OLD power cord's xbox end plug is getting to melting point, then the
new one will still cause injury as its at a high temperature ????? plug at
high temperature, and I remove it from the xbox and touch it to my nose. Now
I dont get it. How can a power cord be faulty ? What if I have a $150 custom
power cord ? what spec does it have to be to be safe ?
Fred Ferd said:So they are making the cord inflammable or have a higher melting point,
David said:I wouldn't trivialise what could be a really serious problem.
Disclaimer - I have no first hand knowledge about the X-Box issue. I
do have first hand knowledge about the following.
Without going into too many specific details there is possibly a
defect in the Figure 8 plug. These plugs are moulded in two parts
(actually more than two, but nonetheless I'll continue) - one part is
the Fig 8 bit, which is then joined onto the cord achorage assembly
(the other bit). This way you can make different ends for the same
cord-grip moulding. When pushed back against a solid object the
cord flexes at the grip and strains the moulded joint. Usually the
joint is reslient enough to withstand this treatment (rough handling
but expected in normal use). A particular maker of these plugs &
cords uses/used a design that did not withstand this treatment and
which sheared off, either partially or fully. The result was either
a non-exposed broken connection (sometimes with subsequent internal
arcing) or exposed pins at mains potential where the fracture occurs.
The most common interration is the internal fracture which leads to
an overheated plug - arcing due to the inrush current of the PSU
flashing across the fracture. The open fracture leaves exposed mains
and the applicance may continue to work, or work intermittently, or
stop working. The most obvious thing for the user to do in the
latter two cases is to check the cord is properly inserted - burns
have resulted where the user has reached behind the appliance and
bridged the mains with a finger or hand **
Still want to pull it out and touch it to your nose?
Well you could start with AS/NZS/IEC 60227 for the cord and
AS/NZS/IEC 60320 for the Fig 8 plug and then AS/NZS 3112 for the
Aus/NZ plug. Make sure you have a good supply of funds though.
** Safety switches were either not fitted or did not operate - in the
case of an unearthed appliance, and the person is well insulated from
earth themselves, and they contact neutral before active, and they
dirctly bridge neutral and active a bad burn can/may/did happen.
The above issue appeared in Australia over two years ago but I have
no idea if this affects the X-Box. Once again I state I have NO
knowledge of the X-Box issues and do not allude the above applies to
the X-Box. However it uses the same style of connector and I posted
this to answer Fred's "I dont get it. How can a power cord be faulty
?" question. Power cords can be faulty and if they fail it is
possible (even more likely) to be a high risk failure, thats why they
are a 'declared" acticle requiring safety approval. Even then its
not an infallible system.
Right, so you're saying that the X-Box plugs are badly manufactured, are
prone to fracturing, heating, arcing and exposed contacts leading to burns
and/or the knind of electric shock that not even a safety switch can protect
against, and to test this you should hold the plug to your nose?
David said:Thats not what I said, perhaps you should read the whole thread again.
Why did I bother? (rhetorical)
Matthew said:If you haven't read the whole thread, I think you may be
misunderstanding something. David simply explained how the
manufacturing process that makes cords like these (he was overly
concious of not badmouthing the company that makes the cords for
X-Box, damn lawyers) can lead to a weak join that can fracture a
wire. As I'm sure you know, if a wire is broken it will not conduct,
but if it is almost broken, then it will have extremely high
resistance and generate heat.
What you have quoted above was actually you para-phrasing what was
said, like what I have done. The nose comment was something to do
with someone burning there nose. there was no suggestion that is how
you should test for heat.
As for the rhetorical part, that means he doesn't really expect an
answer. More that he was just sitting pondering why he wasted his
time and effort to try to explain something when he ends up with
stupid posts like yours
If you haven't read the whole thread, I think you may bePoxy said:I don't know, but they're pretty bold claims, "rhetorical" or not.
David said:Microsoft are recalling 14.1 million X-Box power cords!
Dave
David L. Jones said:I just got my replacement power cord, that was quick!
I was shocked (no pun intended!) when I opened the box. I was expecting
the same lead but instead I got the lead with an large black box in
series. It looks like an ELCB with a reset button, test button, and an
indicator on it.
conbo said:My wife got the same as you however I got a standard fig 8 power cord.
Her XBox is about a year older than mine, if that helps.
If it was indeed an ELCB - then it would work effectively to protectDoes the X-Box cord have an earth? I assumed it was an double-insulated
device, for which an ELCB doesn't make a lot of sense - perhaps the older
models are having a low-current circuit breaker added to the cord?
Poxy said:Does the X-Box cord have an earth? I assumed it was an double-insulated
"David L. Jones"
No, it doesn't have an earth, it is a stadard 2 pin Fig.8 plug.
As KLR said, it doesn't need an earth pin to work, it can simply detect
the imbalance in the return current.
Dave
***If the Xbox doesnt have an earth pin and is correctly double insulated
how can there possibly be an imbalance in the "return" current.?
