WTB: (or scrounge) 4k x 4 SRAMS, 8168/6168/CY7C168/IMS1420P or equiv
Chris Osborn
I need to replace a couple of bad RAM chips on a Gauntlet board and
can't find any place on the internet to buy some. Need some IMS1420 or
8168 or equiv 4k x 4 srams to replace some bad RAM chips on a Gauntlet
board.
I was going through a stack of computer boards and looking for parts
but didn't see any (lots of 14.318 crystals on video cards
though). Anyone know if there's any old electronics I should keep an
eye out for that might have used these RAM chips? Does anyone have
some of these RAM chips they can sell me?
James Sweet
board.
Did you try Google? I found this http://www.multigame.com/PARTS.HTM in about
3 seconds, there's a bunch more links so you may be able to get a better
price.
Franc Zabkar
Yah I he doesn't have any, and all the other links are requests for
quotes with $100 minimum and/or just lists of data sheets.
I can't help you with the chips, but what I do in these cases is
replace the entire bank of RAM or ROM with a single high capacity
chip. For example, let's say your Gauntlet PCB has 16 chips organised
as 32K x 8. Then you could replace them all with just the one 61256 or
62256 32K x 8 SRAM. These are used as cache RAM in 486 motherboards. I
would remove the 16 chips (keeping them as spares?) and construct a
daughter PCB by wiring it to the address and data lines. If the chip
enables for each of the SRAMs are derived from a 1-of-8 decoder (eg
74LS138), then the high order address bits should be available there.
Of course this is just a hypothetical example, but if you have a
circuit diagram someone here should be able to help you with the real
thing.
- Franc Zabkar
Franc Zabkar
chip.
Is the manual at this site the one for your machine?
http://basementarcade.com/arcade/library/manuals/g/
If so, then I would modify your PCB by removing the SRAMs at 6C-F,
6J-K, 7C-F, and 7J-K, and the 74S139 dual 1-of-4 decoder at 9C. I'd
replace the SRAMs with two 61256 32kx8 SRAMs (because they are
abundant and therefore cheap). One SRAM would be wired to the VRD0-7
data lines, the other to VRD8-15. Wire the RAM address lines, A0-A11,
to VRA0-11, and connect A12 to pins 2 & 14 of 9C, and A13 to pins 3 &
13 of 9C. Connect the CE* pins of the two SRAMs to pins 1 and 15 of
9C, respectively, and connect both OE* pins to the following circuit:
___ 74S00 ___
9C-3/13 ------| \ __| \
| |o----|__| |o-- OE*
9C-2/14 ------|___/ |___/
- Franc Zabkar
