Would a LED short itself?
Mr. Man-wai Chang
Any professor/PhD level explanations? :)
@~@ Remain silent. Nothing from soldiers and magicians is real!
/ v \ Simplicity is Beauty! May the Force and farces be with you!
/( _ )\ (Fedora 18 i686) Linux 3.9.6-200.fc18.i686
^ ^ 00:06:01 up 5:47 0 users load average: 0.01 0.04 0.05
ä¸å€Ÿè²¸! ä¸è©é¨™! ä¸æ´äº¤! ä¸æ‰“交! ä¸æ‰“劫! ä¸è‡ªæ®º! è«‹è€ƒæ…®ç¶œæ´ (CSSA):
http://www.swd.gov.hk/tc/index/site_pubsvc/page_socsecu/sub_addressesa
Mr. Man-wai Chang
It wouldn't. Someone would have to do something to it.
Is it nothing more than a light bulb?
Would you use a current-limiting resistor when you use traditional light
bulb? :)
^ ^ 00:12:02 up 5:53 0 users load average: 0.00 0.01 0.05
Mr. Man-wai Chang
OK, are there 20mA fuses? Isn't a fuse safer than a resistor? :)
^ ^ 00:18:01 up 5:59 0 users load average: 0.08 0.04 0.05
Mr. Man-wai Chang
bulb? :)
And a traditional light bulb could be powered by 110/220 V AC... isn't
it extremely dangerous not to use a current-limiting resistor? :)
^ ^ 00:27:01 up 6:08 0 users load average: 0.03 0.04 0.05
Mr. Man-wai Chang
It depends on the definition of "LED" >:-}
Tell me something I dunno! :)
^ ^ 00:33:01 up 6:14 0 users load average: 0.00 0.03 0.05
Tom Biasi
bulb? :)
An LED is not a light bulb, it's a diode. Light bulbs (as understood to
be incandescent by the tone of this conversation)are resistive and
designed to operate at certain voltages.
Michael Black
bulb? :)
I think you need the newsgroup that's even lower than basics.
An incandescent lightbulb uses a relatively high resistance wire, power
put through that wire causes it to light up. If that lightbulb goes bad,
it would generally open up. The only way it could short is if the
filament collapses on some of the lower wire in just the right way, but if
the bulb was on at the time, the power would just burn out the wire that
remained, too much current going through regular wire.
An LED is a solid state device. There may be instances when they might
short out, but generally they'd just expire, leaving an open circuit.
The resistor that all LEDs need (except for the LEDs that have some
current limiting inside the package) is because the LED is a current
device, it needs a certain amount of current to light up (so long as the
voltage is higher than it's threshold, and lower than the maximum it can
take). If too much current goes into the LED, it can "blow up". It is
different from an incandescent bulb.
Sometimes people do use resistors in series with incandescent bulbs. They
want to limit the current surge through the bulb before the resistance
goes up as it heats up. Or, to limit the actual light out of the bulb,
though there are better ways to do that.
Michael
Mr. Man-wai Chang
What exactly are those instances?
^ ^ 00:42:01 up 6:23 0 users load average: 0.00 0.01 0.05
Mr. Man-wai Chang
May I suggest that you examine the function of those two devices?
You meant I should use both a limiting resistor as well as a 20mA fuse? :)
^ ^ 00:48:01 up 6:29 0 users load average: 0.00 0.01 0.05
More of a Light Emitting Resistor (LER) isn't it? ;-)
Yes! I like it! Henceforth we must call all incandescent light bulbs Light Emitting Resistors!
Oh, wait, by that definition some electric space heaters would also qualify as Light Emitting Resistors, huh.
Mr. Man-wai Chang
So far, that part's been easy.
The difficult part seems to be getting you to understand some simple
concepts.
SO an LED could never be used as a light-emitting fuse?
/( _ )\ May the Force and farces be with you!
^ ^ (x86_64 Ubuntu 9.10) Linux 2.6.39.3
Mr. Man-wai Chang
FYI, the video could also waste your time. :)
Mr. Man-wai Chang
How would you rate its fusing current?
By just applying 3V over the LED, it would draw whatever current needed?
Summarizing the replies from the answers, most said that the LED might
**NOT** always just blow like a fuse. And that's the main reason of
using a current-limiting resistor.
If LED would always die like a fuse without shorting itself, then there
should not be a need for a resistor.
^ ^ 19:39:01 up 2:06 0 users load average: 0.00 0.01 0.05
Tom Biasi
With all due respect this thread is going nowhere fast. You have
received enough information to realize that your logic is severely
flawed and that you need to do some research.
Now I'm suspecting troll activities.
Tom
Mr. Man-wai Chang
OK, let's end this thread! I will use current-limiting resistor. :)
^ ^ 00:57:01 up 7 min 0 users load average: 0.06 0.13 0.10
