Steve Young
Steve Spence said:Which is why you combine a solar hot water heater with a wood boiler, so in
summer the solar provides the DHW, and in winter the wood provides the
baseboard water or infloor radiant hot water as well as the DHW.
Steve, I ignored DHW because of the need to burn a fire during the
summer, coupled with the problems of erratic solar collection, as one might
only get a limited amounts of sun through a day and not have the heat when
needed. A solution with both solar and wood heating, to overcome, or
significantly reduce associated problems, also adding convenience, is to build
heat storage into the equation. It really helps to collect all the heat one
can, as it's available, then parcel it out through several days. I
use a 275 gallon fuel oil tank, (turned into 'thermos jug'), (by having the
tank isolated from the floor and surrounded by 8 inches of fiberglass
insulation)). On my to do list is to expand it to twice this size.
I also want to integrate control, using sensors on the heat sources, to flow
the water only when collector temperature exceeds the tank temperature, etc.
Also to monitor various other temperatures, making it possible to
intelligently automate the system. Solar and wood heat are very compatible and
can be made quite convenient with heat storage.
Steve Young
