Well I had a hard drive crash awhile back, and although I have most of the data backed up it was my primary OS drive and I HATE reconfiguring and reinstalling all my software all over from scratch again...
The drive appears to not be able to 'reset/calibrate'' it's home position, aka the read/write head can't determine it's location...
I attempted the easy route last week by sourcing a like drive and swapping a the like controller board to the bad drive while moving the 'flash' chip off the old board to the new one so that the drive specific information (like bad sectors) was cloned to the new board so it would work with the old drive... Well that didn't work, same symptoms...
As I said since it's primarily the OS drive it's not worth the $100s or $1000s to pay to have the data reclaimed by a pro, so now I'm off on an attempt to do it myself...
Been building a 'clean box' tonight, basically a positive air pressure charged box with the air being filtered through a HEPA filter and constantly being forced into the box, and thus air constantly being forced out... In theory since all the 'new' air is HEPA filtered if I leave it run for a period of time it should push all the contaminates out of the box and I should have a pretty darn clean work environment to take a hard drive apart...
I don't need long term reliability out of the repaired drive, as long as I can get it fired up and running for an hour or two I'm golden...
Now, there is a BUNCH and I mean a BUNCH of people blurting out that it's impossible for anyone without a 10-1000 clean room to open a drive without contaminating and destroying it... But, if you dig past all those sky falling preachers you will find that in fact many people have done it at home on a shoe string... Especially in the modding circles where they replace the cover with a piece of plexiglass so you can see it move... No one claims perfection or no contamination, but many claim the drives have worked trouble free for years... Note, that the people doing this have done it on the kitchen table, to a humid bathroom to a homemade clean box to whatever and have had success... Heck I was remodeling an asset recovery companies 'safe/lock room' shortly after Katrina hit, if I told you what I saw them doing to the skids full of mud encrusted computers and hard drives you would cringe but they where in the business of recovery and obviously knew what they were doing... Hundreds of hard drives caked in mud all over the place, and yes on many of the the seals had failed and they had muddy water inside on the platters...
My thoughts are if I build a decent 'clean box' and since I have a decent skill set that I'm way ahead of many and as long as there is no physical damage to the platters (scratches) of the drive I should be able to perform a read/write head swap from the good drive to the bad one and get something off it...
So right now I'm knocking down the dust in the bathroom with a hot shower, going to take the clean box in there and give it a scrub down with lint free rags, distilled water/rubbing alcohol... Last step give it a once over with a tack towel, drop the tools and hard drives in and close it up... Turn on the forced air and let it run for maybe an hour or so...
After that I'll hold my breath and go off to the races...
