Wiring volume pedal
Hi all, i need some help. I've got an old ibabez VL10 volume pedal, two inputs and two outputs, it's very old, and the connectors are broken, I just want to make it mono, so i only need one input and one output. The potentiometer is stereo and i don't know hot to wiring the stereo pot with the two stereo jacks............ Could you help me?? Thanks.
PD: The pedal has another things like, one volume/balance switch, and min/max potentiometer but these are disabled, i'm not interested in use them.
I would put a 470Ω resistor in-line (series) with each input line and a 20kΩ across (parallel) outputs A and B to couple the two signals. Leave everything else as it is.
