Wiring Pencil
G
gecono
I'm trying to purchase/locate a wiring pencil. I am unable to locate
any US based companies selling these. Can anyone suggest where I might
be able to purchase such a pen like the roadrunner or verowire?
Thanks,
George
BTW - As you could have surmised I live in the US ;)
JeffM
Jamie
Thanks,
George
a wire wrap tool and accessories?
john jardine
Thanks,
George
Farnells does 'em. Surely they've some presence in the US?. The spooling
wire is really good for fine repairs.
Ross Herbert
Thanks,
George
They should be available in the US (providing they don't give them
some esoteric name over there).
If all else fails then it won't be too expensive to get one from the
Old Dart http://www.rrunner.co.uk/pens/pens.htm
Al in Dallas
Never heard of Farnells or wiring pencils, but a Roadrunner is either
an automobile or a leggy bird.
Rich Webb
Perhaps the Vector Slit-N-Wrap tool, P/N P-184? Carried by the usual
suspects, Digikey etc.
Rich Grise
AIIIIEEEEE!!! NO NO NO NO NO NO NO!!!! I got stuck having to use
one of those once, and they're a nightmare. For one thing, all
they're good for is daisy-chaining, and the resulting daisy chain
is all wrong if you ever have to unwrap just one or two connections.
And you need a special chisel to cut the wire at the end of a run,
and you have to waste a few inches of wire when you start a thing,
etc, etc, etc...
No. Avoid "Slit-n-Wrap" like the plague.
Cheers!
Rich
Rich Webb
etc, etc, etc...
No special chisel required although I think that you're right, the
tool did come with a flat-bladed cutter back in the dark ages when I
got it. Haven't seen that gizmo for years. A good set of wire cutters
works just as well (better, perhaps).
But it is Da Bomb for daisy-chaining. I rarely use it (or any wire
wrap) nowadays but I do have a "duty" CPLD on a break-out board with
0.1" headers -- for prototyping or the occasional glue -- and it's by
far the fastest way to collect and tie all of the unused pins.
Ross Herbert
Of course, it must have been an automobile then cos these RoadRunners
have a brake as optional. I haven't seen any "leggy birds" with that
provision.....
Rich Grise
I've done some daisy-chaining in my day, but I soldered wire-wrap wire
point-to-point. I filed the rivet off the blade of a WSU-30, and clamped
the blade in an X-Acto handle. I'd strip a few inches of insulation,
solder the end to the first pin, then loop the wire around and lay the
insulated part of the wire along the path I intended to take. I'd grab
the wire there with the tweezers, slide it into the stripper blade, and
slide that chunk of insulation right up to the joint. Then, of course,
the insulation was exactly the right length for the next joint. If I
needed to daisy-chain them, I'd just keep doing the same thing. These
sockets are all already tacked on Vector Pad-Per-Hole, of course. :)
Cheers!
Rich
