Wiring a Finder 80.01.0.240.000 timer relay
I am attempting to wire the above timer relay. What I am trying to accomplish is using a momentary switch to activate the timer for 10 minutes. I currently have 12vDC +to A1 and -to A2 ..... not sure where to go from here.
I do have that wired correctly. If I want instant on and power for 10 minutes how would you recommend the settings? Where should I place the exiting power cables?
I'm not a electric tech and just trying to make this work for a little project.
Thank You......
Set the switch to D1 and apply your power input to 15. Connect your load to 18 and adjust the bue dial for the delay period.
