Thomas G. Marshall
I have a dust buster (hand held vac) that is considered the 7ish volt
version and whose internal battery is charged with a 11 volt (and some small
number of milliamps) AC->DC converter.
Ok, two fundamental questions:
1. If I wire the vac (complete with its battery) to the car's battery (via
the aux "cig lighter" port), is it possible for the car to somehow overwhelm
the vac's battery and fry it? I know that frying is possible when charging
up a car battery with a charger left on manual for too long, so I figure
that maybe batteries are considered shorts in the circuit somehow and will
draw every amp you give it (???) That would mean that the vac battery would
be fried?
2. If I remove the vac battery and just connect the 12V car line to the
motor, will the motor draw just the number of amps it needs? (Ignoring the
difference in voltage, which I'm assuming will only speed up a DC motor).
be fried?
