Wirin diagram for White Knight WK427 dryer
Chris Lewis
Has anyone got a schematic for the above dryer I can have. We have no dryer
and have been given one that someone attempted to repair but removed all the
wiring connections and got confused. After that they bought a new one.
H
Homer J Simpson
dryer
the
Central city library here has repair manuals for all sorts of things - in
library use only.
Christopher Lewis
library use only.
I'm guessing from your response you are in the US. I am in the UK and our
library is crap and has no such useful stuff! :)
H
Homer J Simpson
I've put stuff like that back together, but it depends on the 'features'. A
simple timed drier is pretty easy, but if it detects moisture or has other
complex features you are probably SOL.
Christopher Lewis
A simple timed drier is pretty easy, but if it detects moisture or has
other complex features you are probably SOL.
OK what is SOL? I have had a bit of experience with this sort of thing
myself. Its basically got a timer, high/low settings(which is just 1 or 2
elements on) some king of water sensor gadget and the usual door switches
etc.
I manages to find the manufacturer today and got a e-mail from them saying
if I send them the model code (different to the model number on the front)
they will forward me the service manuals and wiring schematics
Should be sorted by tomorrow night!
Chris
H
Homer J Simpson
OK what is SOL?
Shit Out of Luck.
I have had a bit of experience with this sort of thing myself. Its
basically got a timer, high/low settings(which is just 1 or 2 elements on)
some king of water sensor gadget and the usual door switches etc.
OK. I would try to treat the dryness sensor as a 'lump' and deal with
everything else which is easier.
Chris Lewis
Shit Out of Luck.
Yeah I will do. Fortunately that part still has the connections on its just
the connections to the back of the timer, high/low switch and also some
terminal block on the back panel to join it all up.
Thanks again for your help.
