Hey guys I'm trying to design a simple and small wireless mic that allows tranmission over bluetooth or wifi (only needs to transmit over very short distances - under 5meters is fine)
It needs to be very very simple, as in I don't mind if all it does it continuously transmit data without a switch.
It also needs to be very small (if the board can be no larger then 2cm on a side that would be perfect (I'm using a 3mm x 6mm microphone)
This is for a medically related research project, however I have absolutely no experience in electronics and am currently stuck in the design phase, Any help would be greatly appreciated.
