Hi
I Fly model helicopters and part of this is the use of a simulator.
The simulator uses the every day transmitter (futaba 10c) and connects to a pc using a lead which is connected between the trainer port at the rear of transmitter and a usb port.
This lead uses an anti pirate coding and so has to be used.
Basically the trainer port of the Transmitter is sending out PPM signals which is sent to the pc through the lead.
What I would like to be able to do is send the signal from the Transmitter to the simulator cable wirelessly. So that I can tuck all the cabling behind my pc and connect wirelessly
Any ideas?
Simulator: Phoenix rc
Any ideas?
