My XT machine supports external ROMs. The documentation (which I finally
found online, and is quite well specified) states:
The ROS checks for external ROMs between addresses C0000 and F4000 in 800h
(2k) byte increments. An external ROM which conforms to the following
specification will be initialised by the ROS:
1. The first two bytes contain the hexadecimal value 55AA.
2. The next two bytes contain the size in 512 (1/2K) byte increments.
3. The next byte is the initialization routine entry point.
4. The LS byte of the byte sum of the ROM is zero.
When a ROM conforming to this specification is located then the
initialization entry is called.
If the checksum test fails then an error message is displayed and
initialization is not called.
The IGA BIOS ROM conforms to above standard and if it is enabled, it is
entered (at C0000)...
So the ROS (Resident Operating System, i.e. the BIOS startup code)
initializes whatever's found (which, in my case, includes the hard drive
controller's BIOS and the IGA (Internal Graphics Adapter, which is high
resolution EGA with a whopping 256k RAM)). I could, in principle, burn an
EPROM that conforms to these specifications and run my own programs
instantly on startup.
Tim
Deep Friar: a very philosophical monk.
Website:
http://webpages.charter.net/dawill/tmoranwms
MooseFET said:
This supports my contention that most BIOS's setup the machine to look
like a basic PC (actually about AT class) before trying to boot the
machine from disk.
Many BIOS's such as the one I'm using right now work more like the PC
XT to get the boot done. It uses the "game cartridge" detection by
searching for IIRC A5A5(IIRC)[1] at the start of a memory page. It
finds the PROM of the video card to get the video started and
strangely enough part of the very same PROM that is doing the
searching to get the first version of the disk operations going.
[1] It was about a year ago that I looked it is a pattern like that.
