Wifi Transmission; Energy involved in sending a Wifi Signal
I'm currently working on a project involving Wifi transmission. The device needs to send a 1-3 digit number to a computer/phone that is 5-15 feet away. Approximately how much energy will this take to send one number?
Thank you!
Austin
davenn
Thank you!
Austin
hi Austin
welcome to EP :)
a very odd question
A wifi connection is maintained, once a connection is established with or without data being transmitted
There is continuous background link etc checking going on
do you really need wifi ? Bluetooth would probably be easier
so would you like to tell us what you really mean
Wifi and BT are low transmitter power devices, they will have a minimum power out of maybe around 10 - 20 mW
Dave
Hi Dave. Thanks for the response.
Depending on the range that is needed, I suppose it could use Bluetooth.
What I am trying to get at is: I need to make a system that calculates force in an object when struck (Accelerometer), then sends that force back to a Computer/phone... and it has to power itself, so first, I need to figure out how much energy needs to be generated for each time the Force (1-3 digit number) is sent to the computer, for the system to function.
davenn
BT is good for up to 10m
Power needed in the way u are asking is irrelevent as i said earlier there is going to be continuous power usage. Not just when u send data
Thanks again for the response.
So there would need to be a constant voltage? How would I go about figuring out how much energy has to be generated to power the constant voltage?
You multiply:
  1. the voltage (required by the transmitter and produced by the power source)
  2. by the current (drawn by the transmitter)
  3. by the time (that you want the transmitter operating -- could be minutes, hours, or days)
That gives you an amount of energy required.
From that you can choose an appropriate battery.
