Richard Lane
I believe that POE "power over Ethernet" is required to power a highLarry said:http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%
2FLayout&cid=1160093298732&pagename=Linksys%2FCommon%2FVisitorWrapper
I think Sprint and Linksys have solved the mobile wifi problem for mobile
boaters. Take a look. Linksys has built a cellphone EVDO interface to
plug the Sprint aircard into a wireless wifi router. You get high speed
internet service from Sprint any place Sprint has cellular service across
the country. It won't work in Europe, unless you plug in a European
aircard from one of their carriers.
I picture this aircard/wireless router combo running off a small 115VAC
cable in a sealed-up NEMA enclosure just under the top of the mast on a
cruising sailboat. PCS range from that high up would probably give you
internet service 20 miles offshore via Sprint. Coverage is at:
http://powervision.sprint.com/mobilebroadband/plans/coverage.html
The coverage does not include Charleston, but a Sprint card DOES work in
Charleston and many other places on their 1X slower system, so this
coverage is just the 1Mbps EVDO coverage.
Of course, this costs money.....(c;
On the free, I'm using with great success the WRE54G "Range Expander"
2FLayout&cid=1130267578138&pagename=Linksys%2FCommon%2FVisitorWrapper
This box is $70 at J&R:
http://www.jr.com/JRProductPage.process?Product_Id=3988258
&JRSource=linkshare.datafeed.LKS+WRE54G
a $30 savings from Circuit City's price.
The WRE54G is a "repeater". It connects to what it either automatically
finds (autoconfigure) or what you tell it to connect through over its
ethernet cable (manual configuration). It stores these favorite links
and reconnects to them automatically, like any wifi computer, when it
hears them in range. Once configured, connection is fast and automatic.
Being a repeater, not a router, it simply assumes the SSID of the system
it is repeating. You simply notice your barely useable connection at 20%
has jumped to 90% on your wifi notebook (or here on my Netgear SPH101
Skype phone...(c. I'm carrying one in my car and running it off a tiny
inverter plugged into the cigarette lighter socket. When I get to lunch
and want to play on wifi, I plug in the repeater and just sit it on top
of the car outside the restaurant. It connects automatically to an open
link at the gas station next door to Denny's and I have full wifi service
inside Denny's until I leave.
There IS a disadvantage to this....half speed, which isn't much of an
issue going through a cable or dsl modem that's so slow, anyways. The
repeater receives from A THEN transmits to you, then receives from you
THEN transmits back to A, doubling the packet times as it cannot transmit
and receive simultaneously on the same wifi channel.
If you don't HAVE to have a wireless notebook on the boat, and you don't,
a better solution might be to run Ethernet cable up to the masthead and
install one of the quite powerful wifi access points in a weathershield
at the masthead. You plug the laptop into the remote AP and turn off its
local wifi radio inside it.
They keep getting more powerful. Here's one that runs two TWO WATT wifi
radios!
http://www.valuepointnet.com/products/ruggedap/580g.html
In comparison, your laptop's wifi radio runs about .02 to .05 watts. Of
course, this power boost won't mean much if the marina is running a 20mw
piece of crap on top of a file cabinet for "free internet" service
because you won't be able to hear them very far. But, if the marina has
a professionally-installed wide area wifi system, this AP could
signicantly improve range way beyond the marina's borders.
I'm afraid to ask for a price quote...(c; This is NOT home consumer
equipment. It only costs a little more to go first class, however.
Compare golf cart house batteries to those $500 Surette AGMs....same
idea..(c;
Larry
power WiFi modem via a cat5 cable at the mast head, perhaps a USB
connected device would be better (AirLink).(). Just placing such a $170
PepLink Surf or Buffalo cat5 modem on top of the cabin with a simple
corner reflector would be good enough.
Dick
