Hi all,
The system shown is to time an athlete running a sprint. At the starting end, the runner releases the start button to create a 0.5 sec pulse to the reed relays to start the digital stopwatches.
When the runner breaks the light beam at the finish line, the photo sensor outputs a 0.5 sec pulse to stop the timing.
3 stopwatches are used to verify accuracy, i.e. if all stopwatches agree, then I consider the system to be accurate.
PROBLEM: The stopwatches often don't agree -- The displays can be different by up to 0.04 seconds (40 ms).
=> I would like to know what could cause the different stopwatch indications?
Additional info:
- I can tell that the stopwatches do not start / stop at the same instant, based on mis-synchronized "beep" sound, so the problem is not with the stopwatches themselves. They all use the same basic chip and circuitry, which is accurate to about 3 sec per day which is much less than the time differences.
- The time differences occur randomly -- any of the stopwatches can be faster or slower than the other 2 for any timing instance.
- Response time of the reed relays is only 0.5 ms, also much less than the time differences.
Any help appreciated!
Additional info:
