Who else makes this iPAQ connector?
Boris Mohar
http://makeashorterlink.com/?M2CF4281B
I can get the connector but they will not supply the drawing. I need to make
a accurate footprint for the PC board. Any substitutes?
P.S. Foxconn website is little slow
Regards,
Boris Mohar
Got Knock? - see:
Viatrack Printed Circuit Designs
void _-void-_ in the obvious place
O
OBones
What about ordering one, and then take the measurements yourself. It
should be pretty much standard distance between pins (100 or 50 mils for
instance)
The plastic part is not that hard to model either, it does have to be as
accurate as the pins.
Plus you can always print the pcb footprint at scale 1:1 on a sheet of
paper and have a look to see if it fits.
Boris Mohar
instance)
That is always the last option that I try to avoid.
Regards,
Boris Mohar
Got Knock? - see:
Viatrack Printed Circuit Designs (among other things) http://www.viatrack.ca
