White LED with emission at 400 nm
Steve
Is there a white led that emits down to 400 nm ? The one's I see have
a peak in the blue near 450 nm with a sharp fall off down to 420 or
430 nm. I'd like to use one for absorption spectroscopy down to 400
nm.
Is this due to concerns with UV emission or lack of phosphors most
efficiently excitable by 400 nm ?
http://ledmuseum.home.att.net/specx11.htm
Steve
I don't argue with the technical reasoning behind this statement, and
even if I were I'm certainly not in the position to dispute this with
Dr Roberts. However, I would say that there are valid reasons for
white LED content below 400nm. Namely, the excitation of fluorescent
whitening agents in clothing, papers, and other materials which is in
the 360-400 range. Hence white LED illumination will lose this feature
in comparison to existing illumination methods. I realize this will
not be compelling to many of you, but to folks in the printing and
pulp & paper worlds, it might prove to be very significant.
I've now found the GE Lumination Vio High Power White LED that uses a
405 nm led for excitation and the net emission is from around 380 nm
to beyond 700 nm
http://www.lumination.com/literature/VioDataSheetWEB4_9_08.pdf
http://www.lumination.com/product.php?id=56
Don Klipstein
I have already found that true with 4100K T8 triphosphor fluorescents,
especially with modern electronic ballasts. They produce less UV than
older tech halophosphor fluorescents, specifically "cool white".
It appears to me that a major reason is that the blue phosphor component
in triphosphor lamps of medium and high color temp. absorbs much of the
365-366 nm UV. The halophosphor of older fluorescents passes this
wavelength.
The 404.7 nm wavelength also excites most common blue-glowing optical
brighteners - just to a lesser extent than 365-366 nm. LIkewise, it also
causes some excitation of the blue-glowing component of medium and high
color temp. triphosphor fluorescents. It is also present to a lesser
degree with modern T8 4100K triphosphor fluorescents with electronic
ballasts than with "older tech" "cool white" fluorescents.
- Don Klipstein ([email protected])
Jeff Jonas
Stage effects lighting has "Blacklight" UV LEDs. It's rather difficult
to get real specifications from some of these outfits, so I'm not sure
of the details.
I recall seeing references to UV cureing sources that are LED.
I just read a full page ad/info in Design News
about HPUV: high power ultraviolet LEDs
The page links to
http://www.em.avnet.com/LightSpeed
particularly
LM06: Exploring High-Power Ultraviolet LEDs
http://www.em.avnet.com/ctf_shared/sta/df2df2usa/LightSpeed-Eskow-1206.pdf
