White Knight tumble dryer - drum not turning
Roland Butter
None at all ..... but the drum's knackered in ours (makes one hell of a
clunk on each revolution))
So if you're scrapping it .......
Mine came from the tip 'cos the drum had broken away from the bearing
carrier at the rear. Three small coachbolts and some nylocs and it's
still going nearly five years later. Not bad for a condensing dryer.
On a related note, I notice that condensing dryers always score badly on
energy consumption ratings, but I feel that's a bit unfair. We only use
ours when it's too cold and damp to dry outdoors or on the rack winched
up into the stairwell. In these conditions the heat from a vented dryer
would be lost to the outside world whereas ours is kept in the house,
usually on a day when the heating would be on anyway, so though it uses
more energy and electricity isn't as cheap as gas, at least it isn't
thrown away.
powerstation
James Sweet said:
There's probably two pares of terminals, with each pair connected
together. This is so you can connect more than one wire to each of the two
connections to the capacitor itself.
I have emailed the service manuals including wiring diagram
Peter
