Michael
It is an important question, and I wish there was a certain answer.
But I have seen tantalums with the positive lead marked with +, the
negative lead marked with a bar, but also some with the positive lead
marked with a bar or a bar and a +. The only way to be sure how a
given manufacturer does it is to connect an ohm meter each way and see
which polarity shows the highest leakage resistance or find their data
sheet.
OK I tried it again on the 20Mohm setting - and got different results. (I
keep on forgetting that I'm not using an auto ranging multimeter!) So I
connect the positive lead to the side of the cap with the stripe. It starts
at 0 ohms and just keeps on going till it runs past my mm's limit. I then
short the two cap's leads and try connecting the mm's leads the other way
around - and it does the exact same thing. Now what's strange is if I don't
short the leads of the cap when I switch the mm's test leads around it will
initially give a negative resistance, then eventually work it's way up to a
positive resistance and eventually past my mm's limit. It does this with
both switches. Any idea what I'm doing wrong? If I just connect a 5V psu to
the two leads of the tantalum, will it blow up if it's backwards? Or crack,
or smoke, or show that it has diead? I have about a million of identical
ones - so I can spare a couple. Thanks as always,
Michael
