Which diode to use across relay coil contacts
H
Harry Muscle
I'm putting together a circuit that calls for a diode across the relay
coils. However, it doesn't specify which one to use. I'm using a 12V relay
which draws 0.045A (265 ohm coil). Could someone help me out in choosing
the best diode for the job.
Thanks,
Harry
CFoley1064
Thanks,
Harry
Generally, the diode specified should be twice the voltage across the relay
when it's on, and a surge current rating at least that of the relay current.
To be conservative, choose a diode with forward current rating at least that of
the relay. That gives you a minimum diode spec of V(r) > 24V, and I(fmax) >
45mA. That would lead you to a 1N914 or 1N4148 as a first choice, but I'm
superstitious and never use those for anything other than reed relays. I'd use
a 1N4001 or 1N4002.
Good luck
Chris
Michael A. Terrell
a 1N4001 or 1N4002.
Good luck
Chris
Or go to the 1N4007 diode. its rated at 1000 PIV, and will replace
any of the others in the 1N4001-1N4007 series. It costs the same as the
1N4001, and you only need to stock one part instead of three or four.
2 days!
Michael A. Terrell
Central Florida
Chaos Master
In reply to a radio transmission from Harry Muscle(fake@AT) , located at Mars:
Thanks,
Harry
I've used the 1N4007. It's rated at 1000 PIV so it will replace any other in the
1N400x series.
W
Watson A.Name - Watt Sun, Dark Remover
Thanks,
Harry
Use the Harry Muscle kind, a 1N4002 Rectifier.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
