Hi everyone, base on some suggestions I draw solutions how to multiplex measurment input from batteries.
Which solution can you vote for and give me comment.
- Solution 1: I just use MUX, for example MUX
4067 16-channel analog multiplexer will work at up to 18v. I confuse about how to feed the Vcc to be equal to the MUx input highest voltage.
- Solution 2: I use Mux but there will be one volt divider at each input. I confuse the output volt range of divider whether it's suitable for input of MUX or not.
- Solution 3: I use MUX and relay. just alot of relay used. I'm going to replace relays with switchs to reduce number of relay.
- Solution 4: I used ADC which has both MUX and ADC. I confuse the input voltage of ADC can it work with max 16v.
You can see picture for details.
