Hi.
If either, which version?
Can I download parser software or the html parser / tester package?,
.. as phpBB.com provides a downloadable app from their site called SCEdit.
The user opens Example.HTML then types in BB test-code or uses the WYSIWYG icons, allowing flipping from code to displayed page.
Being interested in coding, and practical purpose on E.P. site, such as creating a table, I want to test BB codes on my computer at home, before submitting code which may not work properly when parsed at server end.
[left][/left][center[/center][right][/right]
are missing from the help code examples on using BB-formatted text syntax.
AFAIK in HTML coding, the opening tab has the variable, closing tab not.
Sorry - I see the parser / display does the lines automatically!
The raw BB code can be shown, (maybe bracketed with plain tags), plus the displayed result?
Regards, FL.
Parser?
Is the new Electronics Point / EETech still using Xenoforo, or phpBB?If either, which version?
Errors Found in BB help
Alignment tabs missing
The alignment tabs[left][/left][center[/center][right][/right]
Table
Shouldn't [TCOL=2][/TCOL=2] be [TCOL=2][/TCOL] ?AFAIK in HTML coding, the opening tab has the variable, closing tab not.
Table border lines?
Table Header1: | Table Header2: |
Table Data1 | Table Data2 |
BB code Test page ?
For those wanting to pre-test the appearance of a page, or whether a non-listed tab will work, can a forum / thread be created, maybe in the help section ?The raw BB code can be shown, (maybe bracketed with plain tags), plus the displayed result?
Regards, FL.
