Where to find 4" 16 ohm speaker?
My fiance gave me a cute little Christmas decoration a couple years ago that has a central "Calliope" which houses a 4" round, 16 ohm and 2 watt speaker. She found it in an antique store.
The speaker seems to be shot semi-shot, and I'd like to replace it. I thought it would be a cinch to just Google for it, but most speakers I see are pro audio quality and very few seem to be rated 16 ohms.
Does anyone know if a source for a speaker like this? If I must use for example a 3" 8 ohm, is there a way to "convert" the speaker to 16 ohms? Probably some dumb questions, but I'm not too knowledgeable about speakers. Thanks for any help!
I looked for a 4", 16 ohm speaker at Parts Express.
A 2W speaker is very cheap with poor sound. 16 ohm speakers were used many years ago, not today.
If you use a modern 8 ohm speaker with an 8 ohm resistor in series with it to prevent the amplifier from exploding then it will not be as loud as when new and it will sound "boomy".
The 50mm (2") 16 Ohm speakers seem easy to get.
If it's only a xmas decoration, it might be worth a thought. Otherwise keep checking Ebay etc. You will find one eventually.
Martin
