Comments below:
Watson A.Name - \"Watt Sun said:
I agree on some points, disagree on others. The lifetime of the LED is
much greater, saving bulb replacement. But the Luxeon Star takes 350
mA, and it will eat up batteries just as fast as a regular bulb. You
say 4 to 7 times longer, but it may be a lot less than that. And it's
$40, which is much more than a good maglite costs.
Well the EverLED also has regulation built in as well. On the
larger D cell maglites It can go for well over 20 hours before
starting to really dim. This is because it's using more of the
battery. A regular bulb will show much more dimming prior to that
even with more life left in the batteries. "dead" batteries with
a regular bulb can be put into a light with the everled and they
can then still produce significant light.
You're right though, it's a bit more than just the LED. The
EverLED only needs 1.5volts (a single cell) to light but can be
used in a 6 cell (9 volt) flashlight. Try putting a 6 cell bulb
into a 1 cell flashlight and with a fresh battery it still will
not be real usable.
BTW, I was also not sure if it was a Luxeon Star or one of
LumiLED's other products being used in the EverLED.
The sacrifice many small flashlights make is they use lithium batteris,
which are smaller and lighter than alkalines, but cost more per wat of
power. So if you're a heavy user, you will pay much more. The cheapest
is to get rechargeable C or D cells, and carry a spare charged set. I
haven't yet seen a drop-in rechargeable replacement for a lithium cell
such as the CR-123.
Yes, this is true, but using the CR-123 with LED technology can
help some. Also, Lithiums do NOT have the problem of alkalines or
any rechargables when used in freezing temperatures.
Even with rechargable batteries though, you'll need to change
them 4-7 times where some LEDs will only need it once. Also, with
the small CR-123 type lights and their high intensity outputs
aren't always useful. You can have too much light. That's why
things like the ARC4+ are intrguing since they can be turned way
down if desired. Although you only get about 30 minutes at top
intensity, it can be extended to over 20 hours on the lower settings.
I have both, right in my hand, and I don't believe what you're saying.
The Arc AAA is only a single LED, the AA cell mini maglite has much more
light output.
I do stand corrected. You are absolutely right in that a fresh AA
minimag with a new unsilvered bulb IS brighter than the ARC AAA
at first. But if you turn them both on and leave them on for,
say, 3 hours or more it won't be. The usable light from the
minimag is gone and you'll have a few more hours of usable light
from the ARC. If you leave the minimag on when it's batteries are
run down, this is one of the things that accelerates the
silvering of the bulb so if you leave both on for, say 10 hours
continues, the ARC will need a single new AAA battery whereas the
mag will need two new AA's and a new bulb if it's to work as well
as it did 10 hours earlier.
However, the light from the ARC is whiter and more even than the
minimag at any setting. In general, I PERSONALLY have found that
the overall performance of the ARC over the minimag has resulted
in my minimag being left unused a lot of the time. YMMV
I shouldn't have misrepresented the total output of the AA
minimag that way though. Thanks for correcting me.
That's the main advantage of LEDs, they last longer. And they don't
change to yellowish amber light when the batteries get weak.
Yes, in part. Also though is the fact that as the batteries wear
out and their Voltage drops, the usable light from the
incandescent drops much faster. For example, I had a nearly
"dead" battery in a Maglite Solitare (the single AAA version).
The mag would only barely glow. I take that battery and put it
into my ARC AAA and it lites up as bright as with a new battery.
I was able to get another couple hours of light out of the
maglite's "dead" battery. And the output of the Solitare when
fresh with new batterys and bulb is about the same as the ARC
(although I prefer the evenness and color of the ARC for reading).
LEDs can not only draw a battery down slower for a given light
output, that can be made to draw them down FURTHER using up more
of the battery before it needs to be disposed of.
LED discussion groups at:
Yeah, hearsay, that's what I call much of your information. :-O
I have a 3Dmaglite with an EverLED, a minmag, a mag solitare, and
an ARC AAA as well as a handlful of other incandescents. I've
experimented a lot and have done my share of research on these.
With the exception of the output mistake that I made and that you
corrected for me, I wouldn't really call it hearsay. However,
there certainly is a lot of it out there.
Again, although I'm not an active member of the forums, I would
encourage anyone interested in these topics to explore the URL:
http://www.candlepowerforums.com
There are some guys there that are very much into the hobby who
are using some very decent methods of doing comparisons on issues
such as these. Check out the reviews forum at:
http://www.candlepowerforums.com/ubbthreads/postlist.php?Cat=&Board=UBB16
There are some interesting collectings of output vs throw and
runtime plots for many different flashlights.
- Jeff
