L
Laurent Lamesch
The application: a discrete 50 Ohm wideband amplifier with
f-3dB >= 100MHz and max 10Vpkpk into 50 Ohm, 20Vpkpk into open circuit.
Topology is a current feedback amplifier with small signal wideband
transistors in the input stage, and the idea is to use fast CRT video
driver transistors for the I to U stage and for the push-pull output driver.
Sanyo had some very intresting devices in their 'Ultra-high Quality
Output Devices' brochure, like the 2SA1403/2SC3597 NPN/PNP pair with
Vceomax=60V, Icmax=500mA, fT=800MHz typ, or Philips had the
BFQ232/BFQ252 pair with Vcermax=95V, Icmax=300mA, fT>1GHz.
Unfortunately, it seems to me that the potential manufacturers of
video transistors which I have looked at (Sanyo, Philips, ST, OnSemi,
Fairchild, Rohm, Panasonic, NEC, Toshiba, Samsung) do not make any
suitable devices any more, if they have ever done so.
Do any CRT driver transistors exist which have some probability to be
available in the next few years?
Another option: Philips still makes some UHF NPN and PNP transistors
with fT=5GHz, Icmax=100mA, however Vceo is limited to 15 or 20V. I
tried to stack two of each of these to get a higher Vcemax, but the
frequency response of the stack isn't sufficient any more.
Still another option: In most datasheets, only Vceo is given. As the
transistors are not operated with open base in the application, how much
can Vceo be exceeded?
Thank you.
Laurent Lamesch
Thank you.
Laurent Lamesch
