where to get video projector bulbs?
dh@.
We have two Sharp XG-V10XU projectors that we need
to get new bulbs for. Can anyone suggest where to get
good prices on projector bulbs? I'd also be interested in
anyone's thoughts about replacing just the bulb and using
the old cage.
Thanks for any help!
David
L
Louis Boyd
Charles said:
It would help us to know where you are!
It might also help if you give the bulb part number.
Check ebay item 7510685216. It closes in 20 minutes from this post.
Al
the old cage.
David
http://www.bulbs.com/
Al
Michael Shaffer
dh@. said:
the old cage.
David
www.1000bulbs.com
dh@.
Doing a search of the part numbers should provide you with a supplier
and price in your area.
The part number for the entire module is BQC-XGV10WU/1. Are you
replacing all four lamps? That could be rather dear, so as you asked,
you should be able to just replace the lamp and not the cage. The
single lamp only part number is LP CLMPF0064CE01. The cage seems to add
a couple hundred bucks to the price.
ICYDN - make sure you follow the instructions for changing out the lamp.
It's a bit more than just swapping them out. A user guide can be
found here:
http://www.sharpusa.com/files/pro_man_xgv10xu.pdf
See page 73.
Thank you! Very helpful info! How did you find out the part numbers,
and how can I find out if there are more?
