Where can I find cheap PLCC to DIP socket ?
Hi :)
I need cheap socket adapter for PLCC 84 pins to DIP
Until now the only one I found
http://www.arieselec.com/
is there some cheaper solution?
More questions :)
About PLCC sockets ...
Is there differences between surface mount and thru hole PLCC sockets
in regard of inserting and removing PLCC IC inside.
If I look at digikey catalogue p.336 it seems that Thru Hole have some
king of "spring" leads to keep the ic inside.
On the suface mount one it seem to be "rigid" leads !?
Does it mean it will bend my IC leads went I insert it inside ?
Will I be able to remove my IC and use it into a Thru Hole socket (for
programming) and reinsert it into my surface mount socket ?
