Whats the difference -volts and GND (0 volts)
In the case of positive volts the potential is positive relative to ground.
In the case of negative volts the ground is positive relative to the voltage terminal.
This means the direction of electricity flow is opposite in the two cases.
Related to water:
Its like pumping water through a pipe or sucking water through a pipe.
davenn
shumifan50 is partly correct
he took one possible meaning of your question
what we dont know from you is if you are referring to -V as in a split rail PSU where you have a +V, 0V and -V
( in which shumifan50's answer is OK)
or if you are just referring to a say a battery or other PSU that is labelled + and -
where the -V = 0V and may also = GND if so connected
can you please clarify which you were referring to
cheers
Dave
Do you know what the difference is between gnd and a positive voltage? Then what you ask is exactly the same, but with the opposite polarity.
An analogous question is "Hi, can someone tell me what the difference is between 6 feet underground and ground level (0 feet)?"
edit: Dave's comment applies to mine as well. It gets more complex if you have a floating ground and you decide to connect it to a rail. In that case whatever you've connected it to becomes ground. In other cases you can have a supply that provides a voltage above and below ground potential, i.e. also having a 0V rail. 0V may or may not be connected to ground. If 0V is connected to gnd, then the +ve side of the supply is above ground, and the -ve is below it.
What I'm referring to is when I have a simple 555 timer circuit with just the -V and +V from a 9 volt battery and I want to fine tune it to a perfect 1Hz symmetrical square wave where would I hookup the GND on the oscilloscopes probe to? And also I am reading a book on op-amps and one of the circuits in the book has a power supply that has -V +V and GND and I was wondering how I would hook that up.
Thanks for the help
davenn
that is referring to the second part of my answer above.... repeated ...
The GND = 0V, goes to the negative rail coming from the battery negative = 0V
That refers to the first part of my answer ... repeated ...
... Op-Amps often run from split rails like that. The O'scope's GND clip would go to the 0V rail
cheers
Dave
So in the simple 555 circuit it would be ok to hook the oscilloscopes GND clip on the probe to -V? And how would I make a split rail power supply?
davenn
Yes
well you dont need one for the 555 circuit
Do you have a specific circuit in mind that you need a split rail supply for ?
Dave
Easiest way to create a split rail supply is to use 2 9V battereis. Connect the - of one ot the + of the other. That becomes 0V and the other - and + are the two rails.
davenn
what Op-Amp specifically ?
not all are designed to work off split rails
show us a specific circuit that you want to build
voltages needed etc then a style of split rail supply can be suggested
BobK has given one good way to produce a low current +9V 0V -9V PSU
Dave
For me this is one of the most misused terms in electronics and even IC manufactures haven't helped matters either by labelling there inputs +V and -V. This is how I use all these terms. The + and - signs merely show the direction of conventional current flow of the circuit. But the use of the -V could indicate a negative supply also but the direction is still the same.
+V = Positive supply voltage of the circuit.
0V = Common return point for circuit current.
-V = Negative supply voltage of the circuit.
GND = Safety earth. I know most people in industry interchange the words GND, 0V and common but I do not, that's just the way I work. Remember the scope will display the difference between the clip and the tip just like a DVM measures voltage but the clip is connected to GND.
So you place your clip on the point you want to measure with respect to. In your case connect the GND clip to your circuit common or 0V this then puts your circuit common at ground potential unless using a battery operated scope or probes that don't have a direct connection to the GND. But your bog standard scope will have it's scope clips connected to GND.
One thing to be aware of is making measurements on other pieces of equipment that are connected to the mains, you could cause a large earth loop and have high currents flowing in you probe clips which could damage the scope or the probe. Not to mentioned frighten the hell out of you when you connected it, giving of a nice spark. Been there done that.
Adam
Adam
I'm using a 741 op-amp and the circuit is attached. Bobk said to use 2 9volts which will work but that increases weight which is a big problem if I'm building a mini class robot sumo because they have a 500g weight limit. So is there another way to get a split rail power supply?
Thanks for the help guys
What supply voltage does the rest of your robot run on? What is that circuit supposed to do in your application? Looks like it just amplifies/buffers the voltage set by VR1, and VR2 biases the inverting input.
If your robot has a single supply of say, 5V, use a rail-to-rail op-amp (the 741 is an ancient, poor performing part by today's standards). If you need a floating ground reference for the op-amp, just use two resistors to form a voltage divider.
Knowing what you need the circuit to do will help us design it better.
And in reference to the original post, voltage is always relative, measured across two points. For example, take BobK's two 9V batteries wired in series. Assuming the batteries are fresh and actually putting out 9V, you can get measurements of +9V, -9V, +18V, or -18V depending on which points you're measuring relative to each other. "Ground" in a circuit is typically the point considered to be 0V for the circuit, and is the common return for most/all of the circuits within. For example, when working with a digital IC, or a 555 timer for that matter, and you're measuring the voltage at the output, you typically measure between that output and "ground".
Most circuits that use a single supply voltage (not a split rail) will use the "-" side of the battery or power supply circuit as the circuit ground, and all voltages in the circuit are positive relative to ground. But that isn't absolutely required. You could have the + side be ground, and have your voltages be negative, if the circuit is designed appropriately. Some older cars have a positive ground electrical system, for example, though negative ground is far more common and all newer cars use a "negative" ground (that just means the - terminal of the battery is tied to ground).
In the case of an op-amp that runs on a "split" supply, you don't absolutely have to use a split supply. You can get by with a single supply as long as you supply a virtual "split" with a voltage divider so that the op-amp is working at the middle of its range, since most op-amps can't work with voltages approaching the rails. For example, if your circuit is running off a 12V battery, a voltage divider could bias the op-amp's inputs at 6V, and if the op-amp can handle voltage up to 1V of either rail, the op-amp can handle inputs and outputs between 1V and 11V relative to the 12V supply, or -5V to +5V relative to the voltage divider's "ground". Circuits using older ops like the 741 always used +/- 15V supplies (for a total supply voltage of 30V) because the 741 can only get within ~1.5-2V of either rail, so to work with a +/-12V signal you need a +/-15V supply. Modern "rail to rail" op-amps can get closer to the rails so they're more suitable for the lower single-supply circuits of today.
The circuit that I posted has nothing to do with my robot sumo the circuit is out of a book that I'm reading. The reason I posted it is because Dave said he would like to see it. All I want to know is how to make a spilt rail power supply that does not need two 9 volt batteries. The circuit that I posted is a difference amplifier. Yes I know that the 741 is not up-to-date but I want to use it because that's what they use in the book.
davenn
I asked you for the split rail voltage you needed
you have not answered the question
Its difficult to give advise when you dont answer questions
Dave
Sorry, the message you quoted was a response to kpatz not you. If you go up a little you can see a circuit with the supply voltage it's 15VDC
I don't see any schematic for a 555 circuit, just mentions of it.
In any case, a 555 circuit won't need a split supply at all.
If you just need a floating ground reference, say for an op-amp, you can use a voltage divider. Do you actually need a split supply for your robot?
This Instructables has a circuit that will split a single supply into +/- at about half the voltage. Here: http://www.instructables.com/id/Split-rail-power-supply-from-a-single-rail-supply/ It's limited in the amount of current available though.
Is your 15V supply from a power supply or a battery?
kpatz there is no 555 timer circuit. What there is is a op-amp circuit that I need a 15VDC split power supply for if you look at my other posts you can find a circuit of it.
The op-amp circuit has nothing to do with a robot.
