Jeffrey C. Dege
What's the best way to drop a voltage, a bit?
Or do I need to?
I'm playing with a small robot, made from FischerTechnik components,
that I'm driving with a Basic Stamp, through a Pololu Micro Dual Serial
Motor Controller.
Both Stamp and Motor controller are powered by an 8-pack of AA NiMHD
batteries, providing c. 10.5 V.
This is well within the capability of the Basic Stamp's onboard voltage
regulator, and the Stamp's regulated 5V output is within the 3.0-5.5V
capacity of the Motor Controller's logic supply.
The question is regarding the Motor Controller's motor supply. This is
spec'ed at 1.8-9.0V, with currents of up to 1 A per motor.
I'm using FischerTechnik's S-motors, which run at 9V, and have a .7A
stall current, so we're fine, there.
The question is whether I should reduce the 10.5V for input to the Motor
Controller, and if so, how?
I see four alternatives:
1. Let it run at 10.5V.
2. Stick in a couple of resistors to create a voltage-divider.
3. Use a voltage regulator.
4. How about a pair of diodes?
The problem is I don't know why which would be preferred over the others.
Any suggestions?
Only justice, and not safety, is consistent with liberty, because safety
can be secured only by prior restraint and punishment of the innocent,
while justice begins with liberty and the concomitant presumption of
innocence and imposes punishment only after the fact.
- Jeffrey Snyder
Or do I need to?
Motor Controller.
Any suggestions?
- Jeffrey Snyder
