I have a question regarding this schematic. I am not that well versed in the determination of all the components I need but I do try.
In the middle you see a 4-Position rotary switch on each of the terminal paths I want to have an LED that lights up AND I want it to be at the deisgnated current level indicated on that line.
For example on the top terminal paths LED1 and then I have a 33 ohm resistor and that should give 2.0mA. I got the schematic from a pdf I downloaded but I added the LED.
I remember from some place and I see it here on the left side of the image R5 that you need to have a resistor in front of the LED in the circuit path I am not sure why but I believe it is critical.
I suppose I could swap the order of the components in each circuit path so the resistor shown comes first but the output amperage is critical. So I am not sure which way is best to have another resistor in front of the LED and then adjust the size of the second one if needed(which I think it would have to be) or to just have the single resistor and adjust it but I do believe I have to have one in front of the LED
So I guess it breaks down this way
Line 1 = R? + LED + R? = 2.0mA
Line 2 = R? + LED + R? = 1.5mA
Line 3 = R? + LED + R? = 1.0mA
Line 4 = R? + LED + R? = 0.5mA
I just need to know how to determine the values of all the R's
the power is 12V and I assume the LM344z will regulate that part OK
The next question is on the on the lower left I want to add an actual meter so I can see the mA from the pot. The SPDT switch will toggle between the fixed settings going through the rotary switch and the a pot that can be manually adjusted( at least that is what I am trying for)
I am not sure if I need a resistor there or if the pot will perform that function as well.
I also added the diode just to the right to block the current coming from the rotary switch circuit path if it is in use (This was a wild guess on my part) but is that correct.
The LEDs are there just to act as indicators as to which circuit is active at any given time.
I hope some one can help me with this as I really do not know where else to go other than forums like this one
