What resistor is needed to make enough heat from a PP3 9V Battery to pop a ballon?
determine the short-circuit current from the battery and then pick a resistor that will draw about half of that current across the battery voltage.
Then get the smallest size resistor you can of this value (probably a surface mount type).
As long as the power isn't applied long enough to make it smoke, you should get enough heat to pop the balloon.
The procedure suggested by steve will give you the fastest possible pop (possibly around a tenth of a second?). R = 4.5V / Isc.
I don't know what temperature it takes to pop a balloon, but here are some practical values of approximately what to expect from an 1/8W (0,125W) resistor in free air.:
150 ohms = 60mA = 0.5W = 90 degrees C.
82 ohms = 110mA = 1W = 150 degrees C.
56 ohms = 150mA = 1.4W = 200 degrees C.
I'd suggest to try using an easily manageable 47 ohm 1/8W resistor, which will yield a considerable temperature but which still won't go up in smoke.
How did you get 150°C and the other values please??
That would be handy to know, I just don't know how to do that calculation. Thanks
I didn't calculate the temperatures, I measured them with a thermal image camera. I didn't calibrate it though so please consider the values as being approximate.
Many resistor datasheets will present a surface temperature at the rated power. The other values (resistance, current, power) are from Ohms law. See Tutorials above.
