What kind of toggle switch is this?
Joe Qwerty
I bought a "DPDT Center Off Toggle" but it doesn't work the way I
thought. It has 6 poles and they assume that the middle 2 poles are
common to each On circuit.
1 6
2 5 Common
3 4
On position One: 1-2, 6-5
Center Off
On position Two: 3-2, 4-5
This is not what I need. I have two seperate circuits which should't be
hooked together in any way. There is no Common connection. I really only
need 4 poles, with center off. Example:
A B
C D
On position One: A-B
Center Off
On position Two: C-D
Does someone make a simple switch like this? What would it be called?
That is, what would I ask for. Thanks for any information.........
Note: I don't want to use relays or more switches. This is being used on
a car and there is little room for extra stuff lke more wires, switches,
or circuits. The kind of switch I need seems so simple, but I can't find
it and I'm not sure what to ask for.
Don Bowey
1 6
2 5 Common
3 4
Center Off
This is a double pole, double throw (DPDT)
A B
C D
Center Off
This is a double pole, single throw (DPST)
Yes, It's a common switch. Ask for a DPST toggle switch. You can probably
find one at a good hardware store or an auto parts store.
default
1 6
2 5 Common
3 4
Center Off
A B
C D
Center Off
Sounds like you already have what you need.
Connect the center two "poles" together with nothing else connected to
them.
Run A and B to the same side of one edge of the switch, and C and D to
the opposite side.
With the switch in the center, nothing is connected to anything else.
With the switch toggle on one end A is connected to B.
With the toggle at the other end C is connected to D.
Isn't that what you want?
Peter Bennett
In our normal terminology, a pole is one circuit - what you are
calling a pole is really called a terminal. So, terminals 1, 2, and 3
form one pole, and 4, 5, and 6 form a second pole. Terminals 2 and 5
are the moving arms of the switch and will (with most toggle switches)
connect to the end terminals opposite to the handle position. As you
have numbered the terminals, if the switch handle is up, you will have
connections between terminals 2 and 3, and between 5 and 4.
1 6
2 5 Common
3 4
Center Off
A B
C D
Center Off
Use the DPDT switch that you have.
Connect your A and B to terminals 1 and 2, and your C and C to 4 and
5.
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
new newsgroup users info : http://vancouver-webpages.com/nnq
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
Peter Bennett
On 9/25/05 2:57 PM, in article [email protected],
No - he needs the DPDT - he doesn't want any connection between A-B
and C-D
Joe Qwerty
them.
the opposite side.
THANKS!!!!
I'm so ashamed...I should have seen that ;-)
You saved me a bunch of trouble. I got it all going now. You just earned
3 brownie points, 4 kudo's, and a bunch of good karma.
Jasen Betts
1 6
2 5 Common
3 4
Center Off
A B
C D
Center Off
use the switch you have.
A=1 B=2 C=5 D=4
Bye.
Jasen
Don Bowey
and C-D
You are correct, I was careless in reading his description.
Tnx
Don
Jamie
1 6
2 5 Common
3 4
Center Off
A B
C D
Center Off
i am sure they make switches that have DPDT with one switch contact
removed but i don't understand why you can't use what you have?
you simply use 1-2 for the A-B and 5-6 for the C-D ?
3 and 6 just arn't connected to anything.
default
That'll work. Two terminals at diagonal corners on the switch aren't
connected . . .
default
THANKS!!!!
I'm always amazed at what can be done with a few switches and a
steering diode or two and a little logical thought.
