What is 'Alt' parameter in grid setting window of eaglecad?
Eagle allows you to define two grids: a standard and an alternative grid. You'd typically work with the default grid. However, if you need to work out fine detail, you may want to use a finer grid. By pressing the ALT key the alternative grid is activated (from the eagle help file).
