What happens inside if statement in code
I am stuck in c structure program. I don't have idea What happens inside if statement in code
Code:
#include<stdio.h>
#include<stdlib.h>
struct s
    int x;
    int y;
int main ()
    struct s *p = NULL;
    p = malloc(sizeof(*p));
    if ( p != NULL )
        printf("%d\n", p-> x);
        p = p -> y;
    free (p );
    return 0;
I guess p is structure pointer point to memory location of structure member x.
Code:
My confusion is whether the pointer is dereferenced or not ?
Where did you get that code from?
If it is from a website, you could ask there.
If it is your code, you should know what you do.
Anyway, I doubt the person who wrote this code knew how to deal with pointers in C.
Code:
Makes no sense: After
Code:
you have reserved memory (allocated memory) for a structure "s", but you haven't initialized the values for x and y. Unless your compiler does that for you (and I wouldn't rely on this), the contents of the memory locations is undefined and the print statement will result in a more or less arbitrary number.
The next statement
Code:
p = p -> y;
also makes no sense to me. "p" is a pointer to a "struct s" element, whereas p -> y is an integer. While some compilers may create code for this, chances are your pointer now points into nirvana.
Try this code (only the relevant snippet shown here):
Code:
    p->x = 27; //  I initialize x and y with defined values
    p->y = 33;
    if ( p != NULL )
        printf("%d\n", p-> x); // prints 27 on the console
        p = p -> y;
        printf("%d\n", p-> y); // prints nothing on my console - may be different on your computer
When you instead try this:
Code:
    p->x = 27;
    p->y = 33;
    if ( p != NULL )
You'll see actually 27 and 33 printed on the console.
