"Shaun" wrote in message
"Phil Allison" wrote in message
"Leif Neland"
Phil Allison
Just don't leave the thermometer in the microwave oven with the power on.
** Should be OK with a glass tube and red liquid type.
Measure the temperature of the cold water, then measure the time for it to
boil.
** Bad idea.
Takes far too long, when boiling first begins is not clear and lots of heat
is lost to the air and evaporation.
I measured the power of my previous oven to 230W...
** Using half a litre in a plastic jug for two minutes, I got the answer to
within 10% with a 700W rated oven.
Having a K-type bead thermocouple and digital temp meter made the job
easier
too.
You don't run it till boiling! once you get close to boiling point a lot of
extra energy is required to raise it further and make it boil. What you do
is run a glass of cold distilled water measured (temp and volume) in a
container, you could use several stacked Styrofoam cups for insulation and
cover the top with Styrofoam so that the heat generated does not escape and
run the oven till the temperature increase 20 to 50 degrees or so, then
measure the temp, the information will have an equation to convert degrees
rise to microwave power. Google the method - I haven't looked it up lately.
Shaun
Here is the Method from RepairFAQ from Sam:
7.1) Testing the oven - the water heating test
The precise number of degrees a known quantity of water increases in
temperature for a known time and power level is a very accurate test of
the actual useful microwave power. A couple of minutes with a cup of
water and a thermometer will conclusively determine if your microwave
oven is weak or you are just less patient (or the manufacturer of your
frozen dinners has increased their weight - sure, fat chance of that!)
You can skip the heavy math below and jump right to the final result
if you like. However, for those who are interested:
* 1 Calorie (C) will raise the temperature of 1 gram (g) of liquid water
exactly 1 degree Centigrade (DegC) or 9/5 degree Fahrenheit (DegF).
* 1 Calorie is equal to 4.184 Joules (J) or 1 J = .239 C.
* 1 Watt (W) of power is 1 J/s or 1 KW is 1000 J/s.
* 1 cup is 8 ounces (oz) which is 8 x 28.35 g/oz = 226.8 g.
* 1 minute equals 60 s (but you know this!).
Therefore, in one minute, a 1 KW microwave oven will raise the temperature
of 1 cup of water by:
T(rise) = (60 s * 1000 J/s * .239C/J * (g * DegC)/C)/(226.8 g) = 63
DegC.
Or, if your prefer Fahrenheit: 114 DegF.
To account for estimated losses due to conduction, convection, and imperfect
power transfer, I suggest using temperature rises of 60 DegC and 109 DegF.
Therefore, a very simple test is to place a measured cup of water in the
microwave from the tap and measure its temperature before and after heating
for exactly 1 minute on HIGH. Scale the expected temperature rise by the
ratio of the microwave (not AC line) power of your oven compared to a 1 KW
unit.
Or, from a Litton microwave handbook:
Heat one Liter (L) of water on HIGH for 1 minute.
Oven power = temperature rise in DegC multiplied by 70.
Use a plastic container rather than a glass one to minimize the needed
energy loss to raise its temperature by conduction from the hot water.
There will be some losses due to convection but this should not be that
significant for these short tests.
(Note: if the water is boiling when it comes out - at 100 DegC or 212 DegF,
then the test is invalid - use colder water or a shorter time.)
The intermediate power levels can be tested as well. The heating effect of
a microwave oven is nearly linear. Thus, a cup of water should take nearly
roughly twice as long to heat a specific number of degrees on 50% power or
3.3 times as long on 30% power as on full power. However, for low power
tests, increasing the time to 2 minutes with 2 cups of water will result
in more accurate measurements due to the long period pulse width power
control use by microwave ovens which may have a cycle of up to 30 seconds.
Any significant discrepancy between your measurements and the specified
microwave power levels - say more than 10 % on HIGH - may indicate a
problem.
(Due to conduction and convection losses as well as the time required to
heat the filament of the magnetron for each on-cycle, the accuracies of
the intermediate power level measurements may be slightly lower).
Shaun
